[GRASS-dev] Re: [GRASS GIS] #1310: Browse button in WxPython GUIs
(for scripts) does not provide a correct file path for WinGRAS
trac at osgeo.org
Sat Mar 26 14:15:46 EDT 2011
#1310: Browse button in WxPython GUIs (for scripts) does not provide a correct
Reporter: katrineggert1980 | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.1
Component: wxGUI | Version: 6.4.1 RCs
Keywords: winGRASS | Platform: MSWindows XP
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:6 neteler]:
> Yes, you forgot to take out ">". Try this code:
r.out.xyz input=elevation at PERMANENT output=C:\wd\test\test.xyz
ERROR: Kann Datei <C:wdtesttest.xyz> nicht zum Schreiben öffnen.
(Sat Mar 26 19:14:10 2011) Command finished (0 sec)
so no change regarding the path issue.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:7>
