[GRASS-dev] Re: [GRASS GIS] #1353: ./configure with ffmpeg x86_64 -
problem, with workaround
trac at osgeo.org
Mon May 2 12:47:21 EDT 2011
#1353: ./configure with ffmpeg x86_64 - problem, with workaround
Reporter: geep999 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 6.4.1 RCs
Keywords: | Platform: Linux
Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:1353 geep999]:
> This happens because ./configure is looking for:
> /usr/lib64/libavcodec.so /usr/lib64/libavformat.so
/usr/lib64/libavutil.so
> But on my 64bit Slackware 13.37 they are installed in:
> /usr/lib64/libavcodec64.so /usr/lib64/libavformat64.so
/usr/lib64/libavutil64.so
> Making soft links cures the problem, but perhaps ./configure could be
upgraded.
What does:
pkg-config --libs libavcodec
say?
If it points to the 64-bit libraries, we could try that. OTOH, if the
64-bit version is a separate package (from pkg-config's perspective), that
doesn't help.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1353#comment:1>
