[GRASS-dev] Re: Current SVN problems: SSL certificate has expired
Markus Neteler
neteler at osgeo.org
Tue May 3 03:58:15 EDT 2011
Hi devs,
SVN should function normally again.
Markus
On Mon, May 2, 2011 at 2:14 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi devs,
> with start of 1st May 2011 you will face connection problems with the
> OSGeo SVN server:
> "This Connection is Untrusted ..." or
> and likely something like this:
> [neteler at north raster]$ svn ci -m"html slightly prettified"
> Error validating server certificate for 'https://svn.osgeo.org:443':
> - The certificate has expired.
> The reason is at it stated: the renew SSL certificate wasn't done in
> time by the person in charge.
> We (us) can only hope that the problem is addressed ASAP.
> Markus
