[GRASS-dev] Re: [GRASS GIS] #1355: Error starting wxpython v.digit
session
trac at osgeo.org
Tue May 3 13:42:51 EDT 2011
#1355: Error starting wxpython v.digit session
Reporter: epatton | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.2
Component: Python ctypes | Version: svn-develbranch6
Keywords: G_gisinit() | Platform: Linux
Cpu: x86-32 |
Changes (by martinl):
* cc: grass-dev@… (added)
* owner: grass-dev@… => martinl
* status: new => assigned
* milestone: 6.5.0 => 6.4.2
Old description:
> This error is printed to the Layer Manager output window when I try to
> start editing an existing vector. I select "Digitize" from the drop-down
> box on the Map Display, and then select the name of my vector under the
> left-most drop-down box in the Map Display. The Map Display doesn't draw
> any of my GIS layers, but goes completely white at this point.
> I have rebuilt the vector topology, but the error still occurs. I have
> tested the wxgui digitizer in a different mapset with a different vector,
> with the same error occurring.
> ~ Eric.
New description:
This error is printed to the Layer Manager o utput window when I try to
~ Eric.
Comment:
Hopefully fixed in r46171.
BTW, vector digizer in 6.4.2+ needs some testing. The component has been
recently ported from C++ to Python. It would be good to catch & fix major
part of possible bugs before we release 6.4.2 as the first version with
working wxGUI vector digitizer (including winGRASS).
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1355#comment:2>
