[GRASS-dev] Re: [GRASS GIS] #1355: Error starting wxpython v.digit
session
trac at osgeo.org
Wed May 4 11:57:15 EDT 2011
#1355: Error starting wxpython v.digit session
Reporter: epatton | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: svn-develbranch6
Keywords: digitizer | Platform: Linux
Cpu: x86-32 |
Comment(by epatton):
Using the NC simpler subset, add the boundary_region vector to the layer
manager, choose 'Digitize' from the drop-down menu in the right-hand
corner of the Map Display, choose 'boundary_region' from the left drop-
down menu of the left-corner of the Map Display, then after the nodes and
centroids become visible, try zooming or panning - nothing should happen.
If I then try to erase and re-display the map window, I get the following
error (which is different from the one posted yesterday - not sure why)
File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/ma
pdisp.py", line 571, in OnRender
self.MapWindow.display.SetSelected([])
AttributeError
'VDigitWindow' object has no attribute 'display'
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1355#comment:7>
