[GRASS-dev] Re: [GRASS GIS] #1099: GRASS 6.4SVN with MSYS fails to
start startup screen
trac at osgeo.org
Sun May 8 13:36:17 EDT 2011
#1099: GRASS 6.4SVN with MSYS fails to start startup screen
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: svn-releasebranch64
Keywords: wingrass, wxgui | Platform: MSWindows Vista
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:9 marisn]:
> As nobody has commented on this issue or screamed around in user mailing
list - I suggest to drop "GRASS with MSYS" shortcut from installer at all.
Nobody uses it anyway.
I'm often using "GRASS 6.4.SVN with MSYS", so at least one .... ;o)
> Yes, it's still broken.
tested with actual nightly WinGRASS-6.4.SVN-r46194-1-Setup.exe on Vista32
(on different machines - german locale - with and without existing
locations ect)
it's working without any problem.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1099#comment:11>
