[GRASS-dev] Re: [GRASS GIS] #854: g.extension does not work on a
Mac (probably not on Windows either
trac at osgeo.org
Sun May 8 19:47:26 EDT 2011
#854: g.extension does not work on a Mac (probably not on Windows either
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Installation | Version: svn-trunk
Keywords: g.extension, addons | Platform: All
Cpu: OSX/Intel |
Comment(by kyngchaos):
I got a chance to poke around.
Problems I identified:
* as mentioned on the mailing list, $GRASS_ADDON_PATH can't be used
because g.extension needs a single path, while GRASS_ADDON_PATH can have
multiple paths, and does in my Mac distribution (a global and user addon
path). The workaround is to specify the user path when running
g.extension. That's:
* `/Library/GRASS/6.4/Modules` for the global path for GRASS 6.4 (and
6.5, just change the version in the path)
* `~/Library/GRASS/6.4/Modules` for the user path (and similar for 6.5)
*`/Library/Application Support/GRASS/7.0/Modules` for the global path
for GRASS 7.0 (and similar for future versions)
*`~/Library/Application Support/GRASS/7.0/Modules` for the user path
* the makefile parts are hardwired to the source. This can be overridden
when running make, it's just a matter of figuring out which to do.
* the compile stage compiles to ARCH_DISTDIR, which is constructed from
GISBASE, which is the installed app. Even if the user uses a prefix that
they have permissions to, they will still need admin privileges to compile
* mkhtml.sh and g.html2man are not installed, so installation only
partially succeeds - binaries are installed but not help files, and
g.extension reports it as a failed install.
I was able to get partial compilation and installation (without the help
files) by overriding a few more make variables (patch attached):
* ARCH_DISTDIR = TMPDIR/dist
* ARCH_LIBDIR = GISBASE/lib
* ARCH_INC = GISBASE/include, MYINST_DIR/include and TMPDIR/dist/include
* ARCH_LIBPATH = GISBASE/lib, MYINST_DIR/lib and TMPDIR/dist/lib
This will also find addon includes and libs that might be needed from
another addon (ie for a group of addons).
Fixing help compilation needs some more changes:
* install tools/mkhtml.sh and tools/g.html2man
* mkhtml.sh is found from MODULE_TOPDIR (in html.make), so that should
work, but g.html2man is found from GRASS_HOME (in man.make). Either
change man.make to use MODULE_TOPDIR for consistency, or add another make
override for GRASS_HOME.
Ticket URL: <https://trac.osgeo.org/grass/ticket/854#comment:5>
