[GRASS-dev] Re: [GRASS GIS] #854: g.extension does not work on a
Mac (probably not on Windows either
trac at osgeo.org
Mon May 9 20:08:47 EDT 2011
#854: g.extension does not work on a Mac (probably not on Windows either
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Installation | Version: 6.4.1 RCs
Keywords: g.extension, addons | Platform: All
Cpu: All |
Comment(by kyngchaos):
OK, the help files issue is partly my fault for OS X - the OS X install
was missing the tools dir, and the main GRASS makefile does install
mkhtml.sh. Fixed for OS X.
g.html2man still needs to be installed. It looks like mkhtml.sh was
hacked to install into the dist dir during compilation from the main
makefile, instead of from the tools/ makefile, so I'd say just do the same
for g.html2man.
Otherwise, I tested with those installed, plus the man.make change, and
g.extension worked without a failure.
Ticket URL: <http://trac.osgeo.org/grass/ticket/854#comment:8>
