[GRASS-dev] [GRASS GIS] #1362: wxpython GUI closes suddenly
GRASS GIS trac at osgeo.org
Thu May 12 10:09:07 EDT 2011
 Reporter:  lluis                       |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  normal                      |   Milestone:  7.0.0
Component:  wxGUI                       |     Version:  svn-trunk
 Keywords:  wxpython, X Windows error,  |    Platform:  Linux
      Cpu:  x86-64                      |
 I start grass70 with the wxpython interface and when I open a menu or a
 window (for example, when I try to load a vector layer in de map display)
 the GUI closes suddenly and I can read this message in the terminal:
 "GRASS 7.0.svn (girona_4326):~ > The program 'python' received an X Window
 System error.
 This probably reflects a bug in the program.
 The error was 'BadLength (poly request too large or internal Xlib length
 erro'.
   (Details: serial 17612 error_code 16 request_code 153 minor_code 0)
   (Note to programmers: normally, X errors are reported asynchronously;
    that is, you will receive the error a while after causing it.
    To debug your program, run it with the --sync command line
    option to change this behavior. You can then get a meaningful
    backtrace from your debugger if you break on the gdk_x_error()
 function.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1362>
