[GRASS-dev] Re: [GRASS GIS] #854: g.extension does not work on a
Mac (probably not on Windows either
trac at osgeo.org
Thu May 12 15:58:13 EDT 2011
#854: g.extension does not work on a Mac (probably not on Windows either
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Installation | Version: 6.4.1 RCs
Keywords: g.extension, addons | Platform: All
Cpu: All |
Comment(by martinl):
Replying to [comment:9 kyngchaos]:
> In adding the install for g.html2man (r46240 in rel64, r46241 in dev6),
I found an update (r45933) by martinl that did that, though it was broken
(didn't make sure g.html2man subfolder existed). But also he had an old
copy of the Makefile and I had to fix a reversion.
I don't understand fully "he had an old copy", I modified fresh Makefile
from SVN.
> And instead of my changes to g.extension to change ARCH_* vars, martin
hacked platform.make, grass.make and man.make on install to change the
make vars.
Well, I though I have fixed wrongly set variables, probably I was wrong.
> Though it probably needs a few more vars updated to match what I did,
which is the better method? Seems to me to change 1 file, g.extension, is
better than to change 3. But maybe there are other uses for the makefiles
outside g.extension?
I think that makefiles should provide up-to-date variables.
BTW, your commit introduced again 'macosx' directory. What is the reason
for this directory on GNU/Linux or MS Windows? Thanks. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/854#comment:12>
