[GRASS-dev] Re: [GRASS-user] g.extension and GRASS 6.4.1
William Kyngesburye
woklist at kyngchaos.com
Fri May 13 09:43:34 EDT 2011
On May 13, 2011, at 4:39 AM, Hamish wrote:
> wrt when GRASS_ADDON_PATH contains multiple entries, in r46257,8 I've set
> it to just take the first one.
> Mac-- William: would it be better to grab the last one?
> WinGrass-- will the MSYS path ever contain C:\ ?
The user path is first, I think that's reasonable to default to
> finally we should consider what happens on Ubuntu and possibly OSX where
> by default there is no root pw & sudo is used;
I'm not sure what you mean. I've never had any problems running sudo, either directly in the terminal or from a script. It *always* asks for a password and you type in your login (admin) password, and it doesn't matter that root has a null password.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
