[GRASS-dev] Re: [GRASS-user] g.extension and GRASS 6.4.1
William Kyngesburye
woklist at kyngchaos.com
Sun May 15 10:52:18 EDT 2011
On May 15, 2011, at 6:11 AM, Hamish wrote:
> Hamish:
>>> finally we should consider what happens on Ubuntu and
>>> possibly OSX where by default there is no root pw & sudo
>>> is used;
> William:
>> I'm not sure what you mean. I've never had any
>> problems running sudo, either directly in the terminal or
>> from a script. It *always* asks for a password and you
>> type in your login (admin) password, and it doesn't matter
>> that root has a null password.
> I was talking about the -s flag which runs
> su -c "make ... install"
> I don't remember if I notified the list or not, but I've now
> added a -u flag to run
> sudo make ... install
> instead, for those systems which need it.
> so have you been running "sudo g.extension ..." ?
No, i meant sudo for other things.
> Hamish
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
