[GRASS-dev] Re: [GRASS-user] Re: g.extension and GRASS 6.4.1
Hamish
hamish_b at yahoo.com
Sun May 15 19:25:34 EDT 2011
Markus wrote:
> > - g.extension failed upon wrong parameters in Platform.make
> I have implemented a solution for this, please retry from SVN.
some minor coding comments on the implementation detail:
* is original hardcoded to '= /usr/local/' always true?
Platform.make.in has it variable:
prefix = @prefix@
Use $BINDIR instead? it can change:
Usage: grass-$NAME_VER-install.sh \
grass-$NAME_VER.tar.gz [dest_dir] [bin_dir]
# Check for third parameter:
if [ "$3" ] ; then
BINDIR=$3
fi
* sed: instead of calling it 5 times you can just call it once:
sed -e 's+++' \
-e 's+++' \
-e 's+++' \
-e 's+++' \
-e 's+++' \
< "$infile" > "$outfile"
* ${DESTDIR}/include/Make/Platform.make
${} does nothing to protect against spaces in path names. "Double
quote" instead. Use ${} when you need to protect the variable
name from alphanumeric or _ (etc) which would be confused as part
of the variable name. ${} gets evaluated at the expansion stage,
not the command evaluation stage.
Hamish
