[GRASS-dev] proposition for improving i.atcorr GUI (and simplifying
the parameters input file)
Chemin, Yann (IWMI)
Y.Chemin at cgiar.org
Mon May 16 00:04:53 EDT 2011
i.atcorr has a rather complex parameter input file, some of it can be
simplified by transferring the parameter input to the GRASS GUI i.atcorr
dialog box.
it would be beneficial to have a single value input box for:
- Visibility (overwritten by raster input file "visibility")
- if Visibility = 0 then enable value input to Aerosol Optical Depth
- Elevation (overwritten by raster input file "elevation")
Combo Boxes:
- Atmosphere model (combo box with numbers)
- Sensor code input (Would be nice to have a double combo box, platform
first, then sensor band second)
Miscellaneous
Additionally, the central pixel Lat/long can be inferred from
computational window + some proj code available in r.sun/i.latlong, or
maybe as an input lat/long file (if the image covers a vast area it
would be more accurate).
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110516/3a98afca/attachment.html
