[GRASS-dev] Re: [GRASS GIS] #1266: d.vect has problems
trac at osgeo.org
Mon May 16 05:23:39 EDT 2011
Reporter: akbgf | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Resolution: | Keywords: d.vect
Platform: Linux | Cpu: x86-32
Comment(by akbgf):
The problem was still there in r45721, r45915, r46101, and r46198. [[BR]]
There is some change in r46317, now I got an error message.
% make clean [[BR]]
% svn cleanup [[BR]]
% svn up [[BR]]
At revision 46317. [[BR]]
% ./configure --enable-shared --without-mysql --without-sqlite --with-gdal
--without-fftw --with-postgres --with-postgres-includes=/usr/include/pgsql
--with-freetype-includes=/usr/include/freetype2 --with-freetype-
libs=/usr/lib --with-geos=/usr/local/bin/geos-config [[BR]]
% make [[BR]]
% ./bin.i686-pc-linux-gnu/grass70
I load a raster and a vector of 64 areas. [[BR]]
The selection condition for a category (a present category) returns an
error message in the Command console, no change in the display window.
Andres Kuusk
File "/wrk/andres/sw/linux/grass70/dist.i686-pc-linux-
gnu/etc/gui/wxpython/gui_modules/layertree.py", line 233, in
OnIdle
self.mapdisplay.MapWindow.UpdateMap(render = True)
gnu/etc/gui/wxpython/gui_modules/mapdisp_window.py", line
666, in UpdateMap
windres = windres)
gnu/etc/gui/wxpython/gui_modules/render.py", line 868, in
Render
self._renderLayers(force, mapWindow, maps, masks, opacities)
gnu/etc/gui/wxpython/gui_modules/render.py", line 812, in
_renderLayers
if not layer.Render():
gnu/etc/gui/wxpython/gui_modules/render.py", line 158, in
Render
**self.cmd[1])
TypeError
'NoneType' object is not iterable
Ticket URL: <http://trac.osgeo.org/grass/ticket/1266#comment:5>
