[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem
with path to $GISBASE
trac at osgeo.org
Mon May 16 16:41:12 EDT 2011
#1178: WinGrass: g.extension - problem with path to $GISBASE
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.2
Component: Installation | Version: svn-releasebranch64
Keywords: wingrass, g.extension, path, installation, addons | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:34 hellik]:
> Replying to [comment:33 hellik]:
> > Replying to [comment:32 hellik]:
> > > Replying to [comment:31 hellik]:
> > gcc.exe: installation problem, cannot exec `cc1': No such file or
directory
> > cc1.exe lives in the osgeo4w-build-environment in
c:\OSGeo4W\libexec\gcc\mingw32\3.4.5\cc1.exe, but isn't included in the
nightly-wingrass-installer.
> > so cc1.exe should be included in C:\Program Files\GRASS
6.4.SVN\extrabin by the wingrass-installer.
> and in the wingrass-installer there also missing files from
> C:\OSGeo4W\include
> and
> C:\OSGeo4W\lib\gcc\mingw32\3.4.5\include (like stddef.h or stdarg.h)
now I've tried following:
- added manually GISBASE=C:/PROGRA~1/GRASS6~1.SVN to g.extension
- added cc1.exe in C:\Program Files\GRASS 6.4.SVN\extrabin
- added include files from C:\OSGeo4W\include and
C:\OSGeo4W\lib\gcc\mingw32\3.4.5\include in C:\Program Files\GRASS
6.4.SVN\include
then there are some steps further with compiling by g.extension in a
wingrass-installation
GRASS 6.4> g.extension extension=r.stream.order
which: wget: unknown command
WARNUNG: GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
A r.stream.order\main.c
A r.stream.order\description.html
A r.stream.order\global.h
A r.stream.order\io.c
A r.stream.order\order.c
A r.stream.order\Makefile
Checked out revision 46320.
Compiling <r.stream.order>...
C:/PROGRA~1/GRASS6~1.SVN/include/Make/Module.make:25: warning: overriding
comma nds for target `install'
C:/PROGRA~1/GRASS6~1.SVN/include/Make/Rules.make:90: warning: ignoring old
comm ands for target `install'
mkdir -p
C:\gisdata\grassdata/nc_spm_08/user1/.tmp/6948.0/dist/include/grass
mkdir -p C:\gisdata\grassdata/nc_spm_08/user1/.tmp/6948.0/dist/bin
mkdir -p C:\gisdata\grassdata/nc_spm_08/user1/.tmp/6948.0/dist/etc
mkdir -p C:\gisdata\grassdata/nc_spm_08/user1/.tmp/6948.0/dist/driver
mkdir -p C:\gisdata\grassdata/nc_spm_08/user1/.tmp/6948.0/dist/driver/db
mkdir -p C:\gisdata\grassdata/nc_spm_08/user1/.tmp/6948.0/dist/fonts
test -d OBJ.i686-pc-mingw32 || mkdir -p OBJ.i686-pc-mingw32
gcc -IC:/PROGRA~1/GRASS6~1.SVN/include
-I/home/syringia/.grass6/addons/include
-IC:\gisdata\grassdata/nc_spm_08/user1/.tmp/6948.0/dist/include
-I/c/OSGeo4W/in clude -g -O2
-I/c/OSGeo4W/include -I/c/OSGeo4W/include -I/c/OSGeo4W/include
-DPACKAGE=\""grassmods"\" -IC:/PROGRA~1/GRASS6~1.SVN/include
-I/home/syringia
/include -o OBJ.i686-pc-mingw32/io.o -c io.c
In file included from C:/PROGRA~1/GRASS6~1.SVN/include/grass/gis.h:651,
from global.h:5,
from io.c:2:
C:/PROGRA~1/GRASS6~1.SVN/include/grass/gisdefs.h:129: warning:
`libintl_printf' is an
unrecognized format function type
C:/PROGRA~1/GRASS6~1.SVN/include/grass/gisdefs.h:418: warning:
C:/PROGRA~1/GRASS6~1.SVN/include/grass/gisdefs.h:429: warning:
C:/PROGRA~1/GRASS6~1.SVN/include/grass/gisdefs.h:457: warning:
C:/PROGRA~1/GRASS6~1.SVN/include/grass/gisdefs.h:459: warning:
C:/PROGRA~1/GRASS6~1.SVN/include/grass/gisdefs.h:461: warning:
C:/PROGRA~1/GRASS6~1.SVN/include/grass/gisdefs.h:463: warning:
C:/PROGRA~1/GRASS6~1.SVN/include/grass/gisdefs.h:464: warning:
C:/PROGRA~1/GRASS6~1.SVN/include/grass/gisdefs.h:1114: warning:
`libintl_printf ' is an
-I/home/syringia
/include -o OBJ.i686-pc-mingw32/main.o -c main.c
from global.h:5,
from main.c:19:
-I/home/syringia
/include -o OBJ.i686-pc-mingw32/order.o -c order.c
from global.h:5,
from order.c:4:
gcc -LC:/PROGRA~1/GRASS6~1.SVN/lib -L/home/syringia/.grass6/addons/lib
-LC:\gis
data\grassdata/nc_spm_08/user1/.tmp/6948.0/dist/lib -Wl,--export-dynamic,
--enab le-runtime-pseudo-reloc
-L/c/OSGeo4W/lib -L/osgeo4w/usr/src/grass64_release/ms
windows/osgeo4w/lib -o
t/bin/r.stream.order.exe OBJ.i686-pc-mingw32/io.o OBJ.i686-pc-
mingw32/main.o OB J.i686-pc-
mingw32/order.o C:/PROGRA~1/GRASS6~1.SVN/lib/gis/OBJ.i686-pc-mingw32/
fmode.o -lgrass_vect.6.4.2svn -lgrass_dbmibase.6.4.2svn
-lgrass_gis.6.4.2svn -l
grass_datetime.6.4.2svn -lxdr -liberty -lws2_32 -lz -lintl
-lgrass_dbmic lient.6.4.2svn
-lgrass_dbmibase.6.4.2svn -lgrass_gis.6.4.2svn -lgrass_datetime.
6.4.2svn -lxdr -liberty -lws2_32 -lz -lintl -lgrass_gis.6.4.2svn
-lgrass _datetime.6.4.2svn -lxdr
-liberty -lws2_32 -lz -lintl -lgrass_dgl.6.4.2s
vn -lgrass_dig2.6.4.2svn -lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn
-lxdr - liberty -lws2_32 -lz
-lintl -lgrass_rtree.6.4.2svn -lgrass_gis.6.4.2svn
-lgrass_datetime.6.4.2svn -lxdr -liberty -lws2_32 -lz -lintl
-lgrass_link m.6.4.2svn
-lgrass_rtree.6.4.2svn -lgrass_dig2.6.4.2svn -lgrass_gis.6.4.2svn -
-lgrass_rtree .6.4.2svn
-lgrass_dgl.6.4.2svn -lgrass_rtree.6.4.2svn -lgrass_linkm.6.4.2svn -
lgrass_dbmiclient.6.4.2svn -lgrass_dbmibase.6.4.2svn -lgrass_gis.6.4.2svn
-lgra ss_datetime.6.4.2svn -lxdr
2svn -lgrass_datetime.6.4.2svn -lxdr -liberty -lws2_32 -lz -lintl
-lgras s_dbmibase.6.4.2svn
-lgrass_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lxdr -liber
ty -lws2_32 -lz -lintl /c/OSGeo4W/lib/gdal_i.lib
/c/OSGeo4W/lib/geos_c_ i.lib
-lgeos_c_i -lgrass_dbmiclient.6.4.2svn -lgrass_dbmibase.6.4.2svn -lgrass
_gis.6.4.2svn -lgrass_datetime.6.4.2svn -lxdr -liberty -lws2_32 -lz
z -lintl -lgrass_dbmibase.6.4.2svn -lgrass_gis.6.4.2svn
-lgrass_datetime.6. 4.2svn -lxdr
-liberty -lws2_32 -lz -lintl -lgrass_gis.6.4.2svn -lgrass_
datetime.6.4.2svn -lxdr -liberty -lws2_32 -lz -lintl -lxdr -liberty
-lws 2_32 -lz
gcc.exe: C:/PROGRA~1/GRASS6~1.SVN/lib/gis/OBJ.i686-pc-mingw32/fmode.o: No
such file or directory
make: ***
[C:\gisdata\grassdata/nc_spm_08/user1/.tmp/6948.0/dist/bin/r.stream.o
rder.exe] Error 1
FEHLER: Compilation failed, sorry. Please check above error messages.
rm: cannot remove directory
`C:\\gisdata\\grassdata/nc_spm_08/user1/.tmp/6948.0
/r.stream.order': Permission denied
GRASS 6.4>
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1178#comment:35>
