[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem with path to $GISBASE
GRASS GIS trac at osgeo.org
Tue May 17 16:51:26 EDT 2011
 Reporter:  hellik                                             |       Owner:  grass-dev@…
     Type:  defect                                             |      Status:  new
 Priority:  major                                              |   Milestone:  6.4.2
Component:  Installation                                       |     Version:  svn-releasebranch64
 Keywords:  wingrass, g.extension, path, installation, addons  |    Platform:  MSWindows Vista
      Cpu:  x86-32                                             |
Comment(by hellik):
 Replying to [comment:38 neteler]:
 > I suspect that the update from r46315 needs also to go into the
 > "make install" target in the main Makefile of GRASS.
 I've tested this now with a self compiled grass65svn where the startup
 script is in
 C:\OSGeo4W\usr\src\grass6_devel\bin.i686-pc-mingw32
 and all the rest is in
 C:\OSGeo4W\usr\src\grass6_devel\dist.i686-pc-mingw32
 GRASS 6.5> g.extension extension=r.stream.order
 WARNUNG: GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
 Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
 A    r.stream.order\main.c
 A    r.stream.order\description.html
 A    r.stream.order\global.h
 A    r.stream.order\io.c
 A    r.stream.order\order.c
 A    r.stream.order\Makefile
 Checked out revision 46330.
 Compiling <r.stream.order>...
 c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
 mingw32/include/Make/Module.make:2
 5: warning: overriding commands for target `install'
 mingw32/include/Make/Rules.make:90
 : warning: ignoring old commands for target `install'
 mkdir -p C:\gisdata\grassdata/nc_spm_08/g65/.tmp/7172.0/dist/include/grass
 mkdir -p C:\gisdata\grassdata/nc_spm_08/g65/.tmp/7172.0/dist/bin
 mkdir -p C:\gisdata\grassdata/nc_spm_08/g65/.tmp/7172.0/dist/etc
 mkdir -p C:\gisdata\grassdata/nc_spm_08/g65/.tmp/7172.0/dist/driver
 mkdir -p C:\gisdata\grassdata/nc_spm_08/g65/.tmp/7172.0/dist/driver/db
 mkdir -p C:\gisdata\grassdata/nc_spm_08/g65/.tmp/7172.0/dist/fonts
 test -d OBJ.i686-pc-mingw32 || mkdir -p OBJ.i686-pc-mingw32
 gcc -Ic:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/include
 -I/c/Users/s
 yringia/.grass6/addons/include
 -IC:\gisdata\grassdata/nc_spm_08/g65/.tmp/7172.0
 /dist/include -I/c/OSGeo4W/include -g -O2  -I/c/OSGeo4W/include
 -I/c/OSGeo4W/i                                               nclude
 -I/c/OSGeo4W/include   -DPACKAGE=\""grassmods"\"  -Ic:/osgeo4w/usr/src/g
 -I/c/Users/syringia/.grass6/addons/inc
 lude -IC:\gisdata\grassdata/nc_spm_08/g65/.tmp/7172.0/dist/include -o
 OBJ.i686-                                               pc-mingw32/io.o -c
 io.c
 In file included from c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
 mingw32/incl
 ude/grass/gis.h:651,
                  from global.h:5,
                  from io.c:2:
 mingw32/include/grass/gisdefs.h:12
 9: warning: `libintl_printf' is an unrecognized format function type
 mingw32/include/grass/gisdefs.h:41
 8: warning: `libintl_printf' is an unrecognized format function type
 mingw32/include/grass/gisdefs.h:42
 mingw32/include/grass/gisdefs.h:45
 7: warning: `libintl_printf' is an unrecognized format function type
 mingw32/include/grass/gisdefs.h:46
 1: warning: `libintl_printf' is an unrecognized format function type
 3: warning: `libintl_printf' is an unrecognized format function type
 4: warning: `libintl_printf' is an unrecognized format function type
 mingw32/include/grass/gisdefs.h:11
 10: warning: `libintl_printf' is an unrecognized format function type
 -I/c/Users/s
 OBJ.i686-                                               pc-mingw32/main.o
 -c main.c
 mingw32/incl
                  from global.h:5,
                  from main.c:19:
 -I/c/Users/s
 OBJ.i686-                                               pc-mingw32/order.o
 -c order.c
 mingw32/incl
                  from global.h:5,
                  from order.c:4:
 gcc -Lc:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/lib
 -L/c/Users/syrin
 gia/.grass6/addons/lib
 -LC:\gisdata\grassdata/nc_spm_08/g65/.tmp/7172.0/dist/li
 b -Wl,--export-dynamic,--enable-runtime-pseudo-reloc  -L/c/OSGeo4W/lib
 -L/c/osg
 eo4w/usr/src/grass6_devel/mswindows/osgeo4w/lib     -o
 spm_08/g65/.tmp/7172.0/dist/bin/r.stream.order.exe OBJ.i686-pc-
 mingw32/io.o OBJ                                               .i686-pc-
 mingw32/main.o OBJ.i686-pc-mingw32/order.o c:/osgeo4w/usr/src/grass6_d
 evel/dist.i686-pc-mingw32/lib/gis/OBJ.i686-pc-mingw32/fmode.o
 -lgrass_vect.6.5.                                               svn
 -lgrass_dbmibase.6.5.svn -lgrass_gis.6.5.svn -lgrass_datetime.6.5.svn
 -lxdr                                                -liberty -lws2_32
 -lz   -lintl   -lgrass_dbmiclient.6.5.svn -lgrass_dbmibas
 e.6.5.svn -lgrass_gis.6.5.svn -lgrass_datetime.6.5.svn -lxdr -liberty
 -lws2_32                                                   -lz   -lintl
 -lgrass_gis.6.5.svn -lgrass_datetime.6.5.svn -lxdr -liberty -
 lws2_32    -lz   -lintl   -lgrass_dgl.6.5.svn -lgrass_dig2.6.5.svn
 -lgrass_gis.                                               6.5.svn
 -lgrass_datetime.6.5.svn -lxdr -liberty -lws2_32    -lz   -lintl  -lgra
 ss_rtree.6.5.svn  -lgrass_gis.6.5.svn -lgrass_datetime.6.5.svn -lxdr
 -liberty -                                               lws2_32    -lz
 -lintl  -lgrass_linkm.6.5.svn -lgrass_rtree.6.5.svn  -lgrass_d
 ig2.6.5.svn -lgrass_gis.6.5.svn -lgrass_datetime.6.5.svn -lxdr -liberty
 -lws2_3                                               2    -lz   -lintl
 -lgrass_rtree.6.5.svn  -lgrass_dgl.6.5.svn -lgrass_rtree.6.5
 .svn -lgrass_linkm.6.5.svn -lgrass_dbmiclient.6.5.svn
 -lgrass_gis.6.5.svn -lgrass_datetime.6.5.svn -lxdr -liberty -lws2_32
 -lz   -                                               lintl
 -lz   -lintl   -lgrass_dbmibase.6.5.svn -lgrass_gis.6.5.svn
 -lgrass_datetime.6                                               .5.svn
 -lxdr -liberty -lws2_32    -lz   -lintl    /c/OSGeo4W/lib/gdal_i.lib /c/
 OSGeo4W/lib/geos_c_i.lib -lgeos_c_i  -lgrass_dbmiclient.6.5.svn
 -lgrass_dbmibas                                               e.6.5.svn
 -lz   -lintl   -lgrass_gis.6.5.svn -lgrass_datetime.6.5.svn -lxdr -liberty
 -                                               lws2_32    -lz   -lintl
 -lgrass_gis.6.5.svn
 -lgrass_datetime.6.5.svn -lxdr -liberty -lws2_32    -lz   -lintl   -lxdr
 -libe                                               rty -lws2_32    -lz
 gcc.exe: c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
 pc-mingw32/fmode.o: No such file or directory
 make: ***
 [C:\gisdata\grassdata/nc_spm_08/g65/.tmp/7172.0/dist/bin/r.stream.ord
 er.exe] Error 1
 FEHLER: Compilation failed, sorry. Please check above error messages.
 rm: cannot remove directory
 `C:\\gisdata\\grassdata/nc_spm_08/g65/.tmp/7172.0/r
 .stream.order': Permission denied
 GRASS 6.5>
 so there is the same error:
 mingw32/lib/gis/OBJ.i686-pc-mingw32/fmode.o: No such file or directory <==
 make: ***
 [C:\gisdata\grassdata/nc_spm_08/g65/.tmp/7172.0/dist/bin/r.stream.order.exe]
 Error 1
 best regards
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1178#comment:39>
