[GRASS-dev] Re: [GRASS GIS] #1364: configure fails to detect X11 on
OS X
trac at osgeo.org
Wed May 18 05:05:49 EDT 2011
#1364: configure fails to detect X11 on OS X
Reporter: snorfalorpagus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Compiling | Version: unspecified
Keywords: | Platform: MacOSX
Cpu: OSX/Intel |
Comment(by glynn):
Replying to [ticket:1364 snorfalorpagus]:
> Patch attached (for 6.5).
There's no point patching the configure script; it's generated by autoconf
from configure.in and aclocal.m4, so any changes will be lost the next
time that the source files are updated (unless we remember to keep
patching it, which is unlikely to happen).
The X stuff is handled by autoconf's AC_PATH_XTRA macro, which uses
AC_PATH_X_XMKMF, which doesn't recognise the .dylib suffix. At least, the
version from 2.13 doesn't. Updating to a later version of autoconf is
probably worthwhile, but it's potentially a lot of work.
In the meantime, it might be possible to override AC_PATH_X_XMKMF with a
fixed local version.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1364#comment:1>
