[GRASS-dev] Re: [GRASS GIS] #1366: When GRASS is launched it stops
because the MSVCR71.DLL is not found
trac at osgeo.org
Wed May 18 09:07:15 EDT 2011
#1366: When GRASS is launched it stops because the MSVCR71.DLL is not found
Reporter: GABRIEL | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone:
Component: Installation | Version: unspecified
Keywords: MSVCR71.dll, error when starting GRASS | Platform: MSWindows XP
Cpu: x86-64 |
Comment(by hellik):
Replying to [ticket:1366 GABRIEL]:
> When GRASS is launched using the screen icon whose properties are:
"C:\Archivos de programa\GRASS 6.4.1\grass64.bat" -wxpython
> inmediately the message (translated from Spanish¨:
> ¨Error when starting the application because the MSCVR71.DLL was not
found. The reinstallation of the application could solve the problem¨
> I´ve installed later the OSGEO4W and the problem continues.
> Then I´ve reinstalled GRASS and the message appears again.
> I was using GRASS, Linux Red Hat for a long time, but now I need it in
my notebook that has a Windows XP(32) operating system. Thanks.
can you try it with a wingrass64svn-nightly-build
(http://wingrass.fsv.cvut.cz/grass64/)?
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1366#comment:1>
