[GRASS-dev] Re: [GRASS GIS] #1149: WinGrass - load
R-installation-path dynamically into PATH
trac at osgeo.org
Sat May 21 19:55:46 EDT 2011
#1149: WinGrass - load R-installation-path dynamically into PATH
Reporter: hellik | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Startup | Version: svn-trunk
Keywords: wingrass, path, R | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:7 hellik]:
> Replying to [comment:6 hellik]:
> > Replying to [comment:5 hellik]:
> > > Replying to [comment:4 hellik]:
> > > > I've attached working patches for WinGrass64svn and WinGrass65.
> > > also now attached a working tested patch for WinGrass70.
> > > after some cleaning of the messages, it would be nice to have it in
all branches.
> > > I'm often coupling R and grass inside a grass-session in windows,
it's a very nice feature for analysing gis-data to have.
> > see also [http://code.google.com/p/batchfiles/ Windows batchfiles for
use with R]
> I've tested following in my win32-vista-box
> - installed nightly build WinGRASS-7.0.SVN-r46330-1-Setup.exe
> - copied the batch-files from http://code.google.com/p/batchfiles/ into
C:\Program Files\GRASS 7.0.SVN\extrabin
> - started "GRASS 7.0.SVN with MSYS" by the desktop-shortcut
> - in the windows-command-line of "GRASS 7.0.SVN with MSYS" it's possible
to start a R-session within a Grass-session (recognizing all Grass-
environment-variables) by typing ''cmd R.bat''
to start a R-GUI-session within a Grass-session (recognizing all Grass-
environment-variables) by typing ''cmd Rgui.bat''
> so I '''strongly recommend''' using the bat-files from
http://code.google.com/p/batchfiles/ for a smoothly
WinGrass-R-integration.
> the bat-files are gpl'ed, so there's maybe no problem to include them in
an wingrass-selfinstaller?
> after some tweaking (i.e. starting from the wxgui, ...), this would be a
great and an all-time improvement coupling wonderfull GIS- and
(geo-)statistic- software in the windows environment.
a small correction
- start "GRASS 7.0.SVN with MSYS"
- type in the command-line-window ''cmd'' for enabling a windows-command-
line
- type ''R.bat'' for starting a R-commandline-session within a wingrass-
session or type ''Rgui.bat'' for starting a R-GUI-session within a
winggrass-session (in both cases recognizing all Grass-environment-
variables)
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1149#comment:8>
