[GRASS-dev] [GRASS GIS] #1369: setPrompt: command not found in GRASS7-svn
GRASS GIS trac at osgeo.org
Sun May 22 08:20:55 EDT 2011
 Reporter:  moovida      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:
Component:  Startup      |     Version:  svn-trunk
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
 The grass7 command shell doesn't appear to permit to have an own
 setPrompt.
 I use a customized one to have some different information/coloring of the
 prompt in the case of git and hg repos:
 function setPrompt(){
     thedate=`date "+%F %T"`
     if [ -d ./.git ]; then
         GITBRANCH="$NC($GREEN$(awk -F '/' '{ print $NF }' .git/HEAD)$NC"
         if [ $(git diff --exit-code > /dev/null 2>&1; echo $?) -eq 1 ] ||
 [ $(git diff-index --cached --quiet --ignore-submodules HEAD --; echo $?)
 -eq 1 ]; then
           GITBRANCH="$GITBRANCH [$RED*$NC"
         else
           GITBRANCH="$GITBRANCH [$MAGENTA-$NC"
         fi
         if [ "x$(git status | grep Untracked)" != "x" ]; then
           GITBRANCH="$GITBRANCH$RED+$NC])"
         else
           GITBRANCH="$GITBRANCH$MAGENTA-$NC])"
         fi
         echo -e "\n${GREEN}GIT:${NC} ${GITBRANCH}"
         echo -e
 "${GREEN}======================================================
 $thedate${NC}\n\n\w >>> "
     elif [ -d ./.hg ]; then
         HGBRANCH="$NC($CYAN$(awk -F '/' '{ print $NF }' .hg/branch)$NC"
         if [ "x`hg status | grep ?`" != "x" ]; then
           HGBRANCH="$HGBRANCH [$RED+$NC])"
         else
           HGBRANCH="$HGBRANCH [$MAGENTA-$NC])"
         fi
         echo -e "\n${CYAN}HG:${NC} ${HGBRANCH}"
         echo -e
 "${CYAN}======================================================
     else
         echo -e
 "${RED}======================================================
     fi
 which leads me to the error in the subject.
 While for example in grass64 I have:
 GRASS 6.4.0+42329 (gbovest):~ > echo $PROMPT_COMMAND
 '/usr/lib/grass64/etc/prompt.sh'
 in grass7 it seems to have changed to:
 PS1="$(setPrompt)"
Ticket URL: <http://trac.osgeo.org/grass/ticket/1369>
