[GRASS-dev] Re: [GRASS GIS] #1369: setPrompt: command not found in
GRASS7-svn
trac at osgeo.org
Mon May 23 15:09:24 EDT 2011
#1369: setPrompt: command not found in GRASS7-svn
Reporter: moovida | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Startup | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: Unspecified |
Description changed by neteler:
Old description:
> The grass7 command shell doesn't appear to permit to have an own
> setPrompt.
> I use a customized one to have some different information/coloring of the
> prompt in the case of git and hg repos:
> function setPrompt(){
> thedate=`date "+%F %T"`
> if [ -d ./.git ]; then
> GITBRANCH="$NC($GREEN$(awk -F '/' '{ print $NF }' .git/HEAD)$NC"
> if [ $(git diff --exit-code > /dev/null 2>&1; echo $?) -eq 1 ] ||
> [ $(git diff-index --cached --quiet --ignore-submodules HEAD --; echo $?)
> -eq 1 ]; then
> GITBRANCH="$GITBRANCH [$RED*$NC"
> else
> GITBRANCH="$GITBRANCH [$MAGENTA-$NC"
> fi
> if [ "x$(git status | grep Untracked)" != "x" ]; then
> GITBRANCH="$GITBRANCH$RED+$NC])"
> else
> GITBRANCH="$GITBRANCH$MAGENTA-$NC])"
> fi
> echo -e "\n${GREEN}GIT:${NC} ${GITBRANCH}"
> echo -e
> "${GREEN}======================================================
> $thedate${NC}\n\n\w >>> "
> elif [ -d ./.hg ]; then
> HGBRANCH="$NC($CYAN$(awk -F '/' '{ print $NF }' .hg/branch)$NC"
> if [ "x`hg status | grep ?`" != "x" ]; then
> HGBRANCH="$HGBRANCH [$RED+$NC])"
> else
> HGBRANCH="$HGBRANCH [$MAGENTA-$NC])"
> fi
> echo -e "\n${CYAN}HG:${NC} ${HGBRANCH}"
> echo -e
> "${CYAN}======================================================
> else
> echo -e
> "${RED}======================================================
> fi
> which leads me to the error in the subject.
> While for example in grass64 I have:
> GRASS 6.4.0+42329 (gbovest):~ > echo $PROMPT_COMMAND
> '/usr/lib/grass64/etc/prompt.sh'
> in grass7 it seems to have changed to:
> PS1="$(setPrompt)"
New description:
setPrompt.
-eq 1 ]; then
else
fi
else
fi
echo -e
else
fi
echo -e
else
echo -e
fi
PS1="$(setPrompt)"
Ticket URL: <https://trac.osgeo.org/grass/ticket/1369#comment:2>
