[GRASS-dev] Re: [GRASS GIS] #1374: psmap window does not open
trac at osgeo.org
Sat May 28 13:54:32 EDT 2011
Reporter: timmie | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Keywords: wx.psmap | Platform: Linux
Cpu: x86-32 |
Comment(by timmie):
Please help me to understand:
In regular GRASS shell I get:
GRASS 6.4.2svn (North-Carolina):~ > g.version
GRASS 6.4.2svn (2011)
In IPython outside the GRASS shell:
$$$ python
Python 2.7.1+ (r271:86832, Apr 11 2011, 18:05:24)
[GCC 4.5.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import sys
>>> sys.path.append("/usr/lib/grass64/etc/python")
>>> import grass.script as grass
>>> grass.version()
File "<stdin>", line 1, in <module>
File "/usr/lib/grass64/etc/python/grass/script/core.py", line 1094, in
version
flags = 'rg')
File "/usr/lib/grass64/etc/python/grass/script/core.py", line 265, in
parse_command
res = read_command(*args, **kwargs)
File "/usr/lib/grass64/etc/python/grass/script/core.py", line 235, in
read_command
ps = pipe_command(*args, **kwargs)
File "/usr/lib/grass64/etc/python/grass/script/core.py", line 212, in
pipe_command
return start_command(*args, **kwargs)
File "/usr/lib/grass64/etc/python/grass/script/core.py", line 174, in
start_command
return Popen(args, **popts)
File "/usr/lib/grass64/etc/python/grass/script/core.py", line 56, in
__init__
startupinfo, creationflags)
File "/usr/lib/python2.7/subprocess.py", line 672, in __init__
errread, errwrite)
File "/usr/lib/python2.7/subprocess.py", line 1213, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
Then I tried from inside GRASS shell:
GRASS 6.4.2svn (North-Carolina):~/src/coding/grass/scripts > python
>>> from grass.script import core as grass
>>> grass.version()
Something seems to be wrong here.
Please help.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1374#comment:3>
