[GRASS-dev] grass7: problem --with-liblas
Markus Metz markus.metz.giswork at googlemail.com
Tue May 31 06:05:41 EDT 2011
On Tue, May 31, 2011 at 10:00 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> I have compiled liblas from the repo [1] and then grass7 with
> `--with-liblas`, unfortunately without success
> configure:6544: checking for liblas-config
> configure:6599: gcc -o conftest -g -Wall
> -Werror-implicit-function-declaration -fno-common -Wextra -Wunused
> -Wl,--export-dynamic conftest.c  -L/usr/local/lib -llas -llas_c
> -L/usr/lib optimized;/usr/lib/libboost_program_options-mt.so;debug;/usr/lib/libboost_program_options-mt.so
> 1>&5
> gcc: error: optimized;/usr/lib/libboost_program_options-mt.so;debug;/usr/lib/libboost_program_options-mt.so:
> No such file or directory
> configure: failed program was:
> #line 6592 "configure"
> #include "confdefs.h"
> #include <liblas/capi/liblas.h>
> int main() {
> LASReader_Create("foo");
> ; return 0; }
> having
> $ gcc --version
> gcc (Debian 4.6.0-10) 4.6.1 20110526 (prerelease)
> $ liblas-config --libs
> -L/usr/local/lib -llas -llas_c -L/usr/lib
> Any hint? Martin
I am not sure if this second line returned by liblas-config --libs
starting with "optimized;" is valid. On my installation, liblas-config
--libs gives me
-L/usr/local/lib -llas -llas_c -L/usr/lib64
/usr/lib64/libboost_program_options-mt.so /usr/local/lib64/libgdal.so
/usr/local/lib64/libgeotiff.so /usr/lib64/libtiff.so
/usr/lib64/libxml2.so /usr/local/lib64/liblaszip.so
Is lasinfo working at all? Just a wild guess: have you changed the
default CMAKE_BUILD_TYPE? And just out of curiosity: can you send me
(offlist) your liblas-config file?
Markus M
