[GRASS-dev] Re: [GRASS GIS] #1485: Cannot save workspace from wxGUI
trac at osgeo.org
Tue Nov 1 00:31:02 EDT 2011
Reporter: venkat | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.2
Component: wxGUI | Version: 6.4.2 RCs
Keywords: wingrass | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by naokiueda):
This #1485 probably same cause as #1380.
I'd like to add a fixed code for 6.4.1. This has done by another GRASS
User, who fixed this also in 6.4.0.
Note that this fix, as it is, does not fit for 6.4.2, because base source
code has changed a lot.
[[BR]]
There are comment-out in etc/wxpython/gui_modules/menuform.py, line 2016 -
2019[[BR]]
[[BR]]
2011 def ParseInterface(self, cmd, parser = processTask):[[BR]]
2012 """!Parse interface[[BR]]
2013[[BR]]
2014 @param cmd command to be parsed (given as list)[[BR]]
2015 """[[BR]]
2016 # enc = locale.getdefaultlocale()[1][[BR]]
2017 # if enc and enc.lower() not in ("utf8", "utf-8"):[[BR]]
2018 # tree =
etree.fromstring(getInterfaceDescription(cmd[0]).decode(enc).encode("utf-8"))[[BR]]
2019 # else:[[BR]]
2020 tree = etree.fromstring(getInterfaceDescription(cmd[0]))[[BR]]
2021[[BR]]
2022 return processTask(tree).GetTask()[[BR]]
[[BR]]
Enabling these line by removing comment-out, will fix this problem in
6.4.1.[[BR]]
[[BR]]
[[BR]]
Also, there need to be two more fix.[[BR]]
[[BR]]
in menuform.py, near line 2132[[BR]]
[[BR]]
2132 def GetCommandInputMapParamKey(self, cmd):[[BR]]
2133 """!Get parameter key for input raster/vector map[[BR]]
2134[[BR]]
2135 @param cmd module name[[BR]]
2136[[BR]]
2137 @return parameter key[[BR]]
2138 @return None on failure[[BR]]
2139 """[[BR]]
2140 # parse the interface decription[[BR]]
2141 if not self.grass_task:[[BR]]
2142 tree =
etree.fromstring(getInterfaceDescription(cmd))[[BR]]
2143 self.grass_task = processTask(tree).GetTask()[[BR]]
2144[[BR]]
2145 for p in self.grass_task.params:[[BR]]
2146 if p.get('name', '') in ('input', 'map'):[[BR]]
2147 age = p.get('age', '')[[BR]]
2148 prompt = p.get('prompt', '')[[BR]]
2149 element = p.get('element', '')[[BR]]
2150 if age == 'old' and[[BR]]
2151 element in ('cell', 'grid3', 'vector')
and[[BR]]
2152 prompt in ('raster', '3d-raster',
'vector'):[[BR]]
2153 return p.get('name', None)[[BR]]
2154 return None[[BR]]
[[BR]]
change as follows[[BR]]
[[BR]]
Before:[[BR]]
2142 tree =
[[BR]]
After Fix:[[BR]]
2142 enc = locale.getdefaultlocale()[1][[BR]]
2143 if enc and enc.lower() not in ("utf8″, “utf-8″):[[BR]]
2144 p = re.compile(enc, re.IGNORECASE)[[BR]]
2145 tree = etree.fromstring(p.sub(’utf-8′,
getInterfaceDescription(cmd)).decode(enc).encode("utf-8″))[[BR]]
2146 else:[[BR]]
2147 tree =
[[BR]]
[[BR]]
[[BR]]
[[BR]]
Also in menuform.py line 1957[[BR]]
[[BR]]
1957 def getInterfaceDescription(cmd):[[BR]]
1958 """!Returns the XML description for the GRASS cmd.[[BR]]
1959[[BR]]
1960 The DTD must be located in $GISBASE/etc/grass-
interface.dtd,[[BR]]
1961 otherwise the parser will not succeed.[[BR]]
1962[[BR]]
1963 @param cmd command (name of GRASS module)[[BR]]
1964 """[[BR]]
1965 try:[[BR]]
1966 cmdout, cmderr = grass.Popen([cmd, '--interface-
description'], stdout = grass.PIPE,[[BR]]
1967 stderr =
grass.PIPE).communicate()[[BR]]
1968 except OSError, e:[[BR]]
1969 raise gcmd.GException, _("Unable to fetch interface
description for command '%s'. "[[BR]]
1970 "Details: %s") % (cmd,
e.value)[[BR]]
1971 if cmderr and cmderr[:7] != 'WARNING':[[BR]]
1972 raise gcmd.GException, _("Unable to fetch interface
1973 "Details: %s") % (cmd, cmderr)[[BR]]
1974[[BR]]
1975 return cmdout.replace('grass-interface.dtd',
os.path.join(globalvar.ETCDIR, 'grass-interface.dtd'))[[BR]]
[[BR]]
[[BR]]
Before:[[BR]]
[[BR]]
After Fix:[[BR]]
1971 if cmderr and cmderr[12:19] != 'WARNING':[[BR]]
[[BR]]
This has to be done because this condition see if error string start with
"WARNING" or not, but as a matter of fact, errot string was
"GRASSINFO_WARNING".[[BR]]
[[BR]]
[[BR]]
There three fixes above solve issue in 6.4.2 (in multi-byte
environmrnt).[[BR]]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1485#comment:9>
