[GRASS-dev] grass - lion and 64bit build
gmail
massimodisasha at gmail.com
Fri Nov 4 08:47:23 EDT 2011
tring to build grass7 on osx lion using wx-2.9-cocoa
the build ends without errors but he told me i can't start the guy for a missed numpy.
any clue about osx 64 support on mac?
wx2.9 cocoa was released as stable version now
i build grass using the x86_64 flags
error log :
Launching 'wxpython' GUI in the background, please wait...
GRASS 7.0.svn (spearfish60 at PERMANENT):~ > wxplot.py: This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries.
File "/Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py", line 70, in <module>
from gui_modules import colorrules
File "/Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/gui_modules/colorrules.py", line 46, in <module>
from nviz_mapdisp import wxUpdateProperties
File "/Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/gui_modules/nviz_mapdisp.py", line 46, in <module>
import wxnviz
File "/Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/gui_modules/wxnviz.py", line 30, in <module>
from numpy import matrix
File "/Library/Python/2.7/site-packages/numpy-2.0.0.dev_35952aa_20111005-py2.7-macosx-10.7-x86_64.egg/numpy/__init__.py", line 137, in <module>
import add_newdocs
File "/Library/Python/2.7/site-packages/numpy-2.0.0.dev_35952aa_20111005-py2.7-macosx-10.7-x86_64.egg/numpy/add_newdocs.py", line 9, in <module>
from numpy.lib import add_newdoc
File "/Library/Python/2.7/site-packages/numpy-2.0.0.dev_35952aa_20111005-py2.7-macosx-10.7-x86_64.egg/numpy/lib/__init__.py", line 4, in <module>
from type_check import *
File "/Library/Python/2.7/site-packages/numpy-2.0.0.dev_35952aa_20111005-py2.7-macosx-10.7-x86_64.egg/numpy/lib/type_check.py", line 8, in <module>
import numpy.core.numeric as _nx
File "/Library/Python/2.7/site-packages/numpy-2.0.0.dev_35952aa_20111005-py2.7-macosx-10.7-x86_64.egg/numpy/core/__init__.py", line 5, in <module>
import multiarray
ImportError: dlopen(/Library/Python/2.7/site-packages/numpy-2.0.0.dev_35952aa_20111005-py2.7-macosx-10.7-x86_64.egg/numpy/core/multiarray.so, 2): no suitable image found. Did find:
/Library/Python/2.7/site-packages/numpy-2.0.0.dev_35952aa_20111005-py2.7-macosx-10.7-x86_64.egg/numpy/core/multiarray.so: mach-o, but wrong architecture
import wxnviz
import add_newdocs
import multiarray
import wxnviz
import add_newdocs
import multiarray
