[GRASS-dev] Re: [GRASS-SVN] r49122 - grass/branches/develbranch_6/include/Make
Martin Landa landa.martin at gmail.com
Sun Nov 6 16:20:00 EST 2011
2011/11/6 Martin Landa <landa.martin at gmail.com>:
> 2011/11/6  <svn_grass at osgeo.org>:
>> Author: hamish
>> Date: 2011-11-06 13:02:08 -0800 (Sun, 06 Nov 2011)
>> New Revision: 49122
>> Modified:
>>   grass/branches/develbranch_6/include/Make/Man.make
>> Log:
>> MODULE_TOPDIR refers to the source code dir, not the installed ARCH_DISTDIR. see the first line of the main Makefile.
> why??? BTW, this commit breaks g.extension for installing scripts, again...
eg.
g.extension ext=g.region.point
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.5.svn sh
/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/tools/g.html2man/g.html2man
/home/martin/grassdata/zod2011/landamar1/.tmp/pierre/2593.0/dist.i686/docs/html/g.region.point.html
/home/martin/grassdata/zod2011/landamar1/.tmp/pierre/2593.0/dist.i686/man/man1/g.region.point.1
1
sh: 0: Can't open
make[2]: *** [/home/martin/grassdata/zod2011/landamar1/.tmp/pierre/2593.0/dist.i686/man/man1/g.region.point.1]
Error 127
make[2]: Leaving directory
`/home/martin/grassdata/zod2011/landamar1/.tmp/pierre/2593.0/g.region.point'
make[1]: *** [mancmd] Error 2
make[1]: Leaving directory
make: *** [/home/martin/grassdata/zod2011/landamar1/.tmp/pierre/2593.0/dist.i686/scripts/g.region.point]
Error 2
ERROR: Compilation failed, sorry. Please check above error messages.
Can you explain your commit a little bit more?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
