[GRASS-dev] Re: [GRASS-SVN] r49124 -
grass/branches/develbranch_6/lib/init
Martin Landa
landa.martin at gmail.com
Tue Nov 8 12:13:54 EST 2011
2011/11/6 <svn_grass at osgeo.org>:
> Author: hamish
> Date: 2011-11-06 13:32:08 -0800 (Sun, 06 Nov 2011)
> New Revision: 49124
> Modified:
> grass/branches/develbranch_6/lib/init/init.sh
> Log:
> clean up GRASS_ADDON_PATH logic & convert echo to a comment. executables
> are already symlinked into the main GRASS_ADDON_PATH dir; bin/ and script/
> may go away soon in gr6; please don't propagate misuse of GRASS_ADDON_PATH
> as an ALT_GISBASE.
> Modified: grass/branches/develbranch_6/lib/init/init.sh
> --- grass/branches/develbranch_6/lib/init/init.sh 2011-11-06 21:22:05 UTC (rev 49123)
> +++ grass/branches/develbranch_6/lib/init/init.sh 2011-11-06 21:32:08 UTC (rev 49124)
> @@ -256,10 +256,10 @@
> LCL=`echo "$LANG" | sed 's/\(..\)\(.*\)/\1/'`
> fi
> +# if it doesn't exist set it to something so that g.extension's default is reasonable
> if [ -z "$GRASS_ADDON_PATH" ] ; then
> - GRASS_ADDON_PATH="$HOME/.grass6/addons/bin:$HOME/.grass6/addons/scripts"
> + GRASS_ADDON_PATH="$HOME/.grass6/addons"
> export GRASS_ADDON_PATH
> - echo "GRASS_ADDON_PATH undefined, using '$GRASS_ADDON_PATH'"
> fi
> PATH="$GISBASE/bin:$GISBASE/scripts:$GRASS_ADDON_PATH:$PATH"
> export PATH
I *really* do not understand this change! It goes completely against
your opinion [1]! Moreover it causes
$ echo $GRASS_ADDON_PATH
/home/martin/.grass6/addons
$ ls ~/.grass6/addons/scripts/
i.atcorr.zodh.py
$ i.atcorr.zodh.py
bash: i.atcorr.zodh.py: command not found
Martin
PS: Now I understand what was wrong during the last remote sensing course :-(
[1] http://lists.osgeo.org/pipermail/grass-user/2011-October/062195.html
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
