[GRASS-dev] Re: [GRASS GIS] #1184: "d.vect display=attr" imply grass open process but doesn't close them.
GRASS GIS trac at osgeo.org
Thu Nov 10 10:09:10 EST 2011
 Reporter:  met               |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  critical          |   Milestone:  6.4.2
Component:  wxGUI             |     Version:  6.4.0
 Keywords:  wingrass, d.vect  |    Platform:  MSWindows XP
      Cpu:  Unspecified       |
Comment(by martinl):
 Replying to [comment:7 mmetz]:
 > Display commands are run through gcmd.!RunCommand() which in turn calls
 grass.script.core.start_command() which in turn calls
 grass.script.core.Popen(). Non-display commands invoked through wxGUI are
 run through gcmd.Popen().
 it's not a question of display or non-display commands.
 `gcmd.!RunCommand()` is used when the GUI waits for command termination.
 In opposite `gcmd.Popen()` is used through `gcmd.CommandThread` which is
 basically reserved for the commands running on the background (eg. those
 launched from wxGUI command prompt).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1184#comment:8>
