[GRASS-dev] Re: [GRASS GIS] #1462: r.walk not working in Lambert
Conformal Conic projection
trac at osgeo.org
Thu Nov 10 10:53:53 EST 2011
#1462: r.walk not working in Lambert Conformal Conic projection
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Raster | Version: svn-releasebranch64
Keywords: r.walk | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
From the dev ml, Oct 11 2011, Claudine Gravel Miguel:
"I think I've found what I thought it wasn't working. I reran the whole
thing on both UTM and conical and when looking at a big region, it seemed
like it wasn't working, but as soon as I zoom the window on the 'center'
point and I recalibrate the colors of the r-walk output, then the paths
appear to be fine, on both locations. I also ran the whole thing in both
6.4.2 and 7 and both works fine. I wonder if the problem you had is the
same, Michael, or if it was different.
I think that te reason why I thought the circle around the center point
was wrong is because I was comparing it to r.walk in lat long, which was
following very closely the results found in r.cost (following the
valleys), which, I know realize, were the wrong type of outcome.
So, I guess my part of the problem is resolved. Thanks for your help!"
Close ticket?
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1462#comment:3>
