[GRASS-dev] Re: [GRASS GIS] #1488: v.in.dxf wrapper not working
GRASS GIS trac at osgeo.org
Thu Nov 10 16:05:35 EST 2011
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:  v.in.dxf     |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by cmbarton):
 OK. This seems to be some kind of OS X 10.7 (AKA Lion) issue. It does work
 fine on my OS X 10.6 (Snow Leopard) machine it was compiled on, but gives
 the following error on my Lion laptop.
   File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc
 /python/wx/lib/filebrowsebutton.py", line 140, in OnChanged
 self.changeCallback(evt)
 /gui/wxpython/gui_modules/gdialogs.py", line 1946, in
 OnSetDsn
 input = path)
 /gui/wxpython/gui_modules/gcmd.py", line 611, in RunCommand
 stdout, stderr = map(utils.DecodeString, ps.communicate())
 /gui/wxpython/gui_modules/utils.py", line 665, in
 DecodeString
 return string.decode(enc)
   File "/System/Library/Frameworks/Python.framework/Versions
 /2.6/lib/python2.6/encodings/utf_8.py", line 16, in decode
 return codecs.utf_8_decode(input, errors, True)
 UnicodeDecodeError
 'utf8' codec can't decode byte 0xc1 in position 77: invalid
 start byte
 What is the function of "Decodestring" in this context? Is it necessary?
 I'll try building under Lion to see if this goes away.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1488#comment:2>
