[GRASS-dev] Re: [GRASS GIS] #1488: v.in.dxf wrapper not working
trac at osgeo.org
Sat Nov 12 07:20:00 EST 2011
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: v.in.dxf | Platform: Unspecified
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:2 cmbarton]:
'utf8' codec can't decode byte 0xc1 in position 77: invalid start byte
0xc1 is in the range used for start bytes. However, a start byte of 0xc1
implies that the top two bits of the resulting character are "01", which
would mean that it was in the range 0x40-0x7F (64-127), so it should be
encoded as a single-byte character. "Strict" UTF-8 decoders disallow the
use of over-long encodings (i.e. encoding a character using more bytes
than is strictly necessary), requiring encoded representations to be
unique (i.e. character 0x40 must be encoded as '\x40', and not as e.g.
'\xc1\x00').
However, it's far more likely that command is outputting non-UTF-8 data,
which the GUI is then attempting to parse as UTF-8. In general, GRASS
doesn't care about encodings; it just deals with bytes. Unfortunately,
this isn't something which can readily be fixed. GRASS often has to deal
with textual data which has no associated encoding, so there's no way it
can convert it to the locale's encoding (the wx GUI assumes that all text
is in the locale's encoding).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1488#comment:5>
