[GRASS-dev] Re: [GRASS GIS] #1488: v.in.dxf wrapper not working
trac at osgeo.org
Sat Nov 12 20:04:00 EST 2011
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: v.in.dxf | Platform: Unspecified
Cpu: Unspecified |
Comment(by cmbarton):
Replying to [comment:11 glynn]:
> Replying to [comment:7 cmbarton]:
> > After a bit of testing, using 'ignore' works, but 'replace' creates
further errors down the line
> 'ascii' codec can't encode character u'\ufffd' in position
> 0: ordinal not in range(128)
> > Unless there is a compelling reason to do otherwise, I suggest using
'ignore'.
> One option is:
> string.decode(enc, 'replace').replace(u'\ufffd',u'?')
> This will replace unconvertible sequences with question marks, which
provides a clue that the string is an approximation (this is how e.g. "ls"
behaves if it needs to list filenames which contain sequences which cannot
be converted according to the current locale).
This works fine.
> However, if the !EncodeString method is changed to also use 'replace',
the U+FFFD characters can be left alone:
Changing !EncodeString to use replace does not work. There is still the
same error reported above.
> > 'hello\xc1world'.decode('utf-8', 'replace')
> u'hello\ufffdworld'
> > 'hello\xc1world'.decode('utf-8', 'replace').encode('ascii', 'replace')
> 'hello?world'
> > Also, since the "string" module is imported, using "string" as a
variable name in a method so as to produce a code line like
> > string.decode(enc)
> > seems potentially confusing to those reading the code at least, and
potentially to the program. Maybe the variable should be changed to "str"
or something along that line.
> "str" is the actual name of Python's native string type, and of its
constructor, str().
> It doesn't really matter if a parameter or local name shadows a global
or built-in name, so long as you don't need to actually use the name being
shadowed within the function.
> For complex functions, it's easy to forget that a built-in name is being
shadowed, resulting in obscure errors (e.g. "'str' object is not callable"
if you try to use the map() function when "map" is actually a local
variable containing a string). But !EncodeString is only 7 lines.
> Also, utils.py only imports the "string" module for the join() and split
functions, which are used in normalize_whitespace(). Presumably it could
just use the .join() and .split() methods, i.e.:
> return ' '.join(text.split())
This seems like a good idea to simplify the code some.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1488#comment:12>
