[GRASS-dev] Re: [GRASS GIS] #1450: grass 6.4.svn nightly build
fails on startup
trac at osgeo.org
Sun Nov 13 18:45:10 EST 2011
#1450: grass 6.4.svn nightly build fails on startup
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: closed
Priority: critical | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Resolution: fixed | Keywords: wingrass
Platform: MSWindows XP | Cpu: x86-32
Changes (by hamish):
* status: new => closed
* resolution: => fixed
Comment:
re-tested with recent nightly 6.4 WinGRASS build (r49173) on a freshly
installed Windows XP. Problem with GUI startup still exists.
Solution as noted in comment:7 is to install MS's Windows Installer 3.1
Redistributable (v2), followed by the .net v3.5 Framework.
Suggested remedy for this is to note + provide links for the necessary DLL
installers for those that need them in the wingrass README.html notes?
-> added to the wiki page which is linked from README.html:
http://grass.osgeo.org/wiki/WinGRASS_Current_Status#XP.2F2000
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1450#comment:11>
