[GRASS-dev] [GRASS GIS] #1491: python libs shouldn't parse freeform
text fields with parse_key_val()
trac at osgeo.org
Mon Nov 14 02:20:18 EST 2011
#1491: python libs shouldn't parse freeform text fields with parse_key_val()
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python | Version: svn-trunk
Keywords: parsing | Platform: All
Cpu: All |
raster.py and vector.py use core.py's parse_key_val() to evaluate the
results of r.info and v.info, and report the result of `kv[1]` using `=`
as the field separator.
r.info's title, vdatum, and units results, and most of v.info's extended
metadata results can contain free-from text, which can contain `=` chars.
And so text containing that will get cut off and only give the result up
to the first `=`.
vector_info_topo(v.info -t) looks safe to use it.
db.py contains one too, using `:` as the fs, it is easy to imagine this
failing if the database: string is on MS Windows and contains `C:\`, only
the initial drive letter would get through.
raster3d.py's one should be ok, I don't spot any free-form text options in
`r3.info`.
`g.region -g` in core.py should be safe too.
`g.findfile` in core.py won't be safe if the file= path contains a `=`. I
suspect that's safe on MS Windows but not in UNIX?
thanks,
Hamish
ps- r.info and v.info's -g flags restored to their original "show region"
meanings in trunk. maybe `r.info -s` (show res) should get merged into -g,
a bunch of the others could not be eval'd and had to be moved back out.
after doing that it became obvious that leaving the rest was inconsistent
and breaking the meaning of what -g has historically been for, so backed
out as well.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1491>
