[GRASS-dev] Re: [GRASS-SVN] r49205 - in grass/trunk: lib/python raster/r.info
Sören Gebbert soerengebbert at googlemail.com
Mon Nov 14 04:31:06 EST 2011
Hi all,
i agree with Martins point of view. Having just a single flag "-g" to
print all available information in "shell" style makes IMHO much more
sense. It reduces the need for many flags which may change over time
and which confuses module developer and API designer.
Having only a single flag allows that additionally information can be
added without the need for a new flag. This is also very useful when
designing the GRASS Python API.
The implementation of  "-g" in Martins way for r.info, v.info.
r3.info, g.region and many more, helps to implement a convenient and
compatible module behavior.
I use this solution in the temporal extension too.
My 2c
Soeren
2011/11/14 Martin Landa <landa.martin at gmail.com>:
> I highly *disagree* with this revert! Merging very specific options
> which just prints one information to generic `-g` is a good idea (from
> my POV). Please don't revert the commits which are just against your
> *personal* taste! What's the opinion of other developers?
> Martin
> 2011/11/14  <svn_grass at osgeo.org>:
>> Author: hamish
>> Date: 2011-11-13 22:55:13 -0800 (Sun, 13 Nov 2011)
>> New Revision: 49205
>> Modified:
>>   grass/trunk/lib/python/raster.py
>>   grass/trunk/raster/r.info/main.c
>> Log:
>> undo r49166: units, vdatum, and title can not be eval'd so needed to be split out. on doing that it was apparent that -g needs to act the same as g.region and v.info modules -- basic region info only. -s is debatable to belong to -g or not, but -gs is very easy if needed.
>> Modified: grass/trunk/lib/python/raster.py
>> --- grass/trunk/lib/python/raster.py    2011-11-14 06:49:25 UTC (rev 49204)
>> +++ grass/trunk/lib/python/raster.py    2011-11-14 06:55:13 UTC (rev 49205)
>> @@ -73,7 +73,7 @@
>>         else:
>>             return float(s)
>> -    s = read_command('r.info', flags = 'g', map = map)
>> +    s = read_command('r.info', flags = 'rgstmpud', map = map)
>>     kv = parse_key_val(s)
>>     for k in ['min', 'max']:
>>        kv[k] = float_or_null(kv[k])
>> Modified: grass/trunk/raster/r.info/main.c
>> --- grass/trunk/raster/r.info/main.c    2011-11-14 06:49:25 UTC (rev 49204)
>> +++ grass/trunk/raster/r.info/main.c    2011-11-14 06:55:13 UTC (rev 49205)
>> @@ -60,8 +60,9 @@
>>     struct Reclass reclass;
>>     struct GModule *module;
>>     struct Option *opt1;
>> -    struct Flag *gflag, *hflag;
>> +    struct Flag *rflag, *sflag, *tflag, *gflag, *hflag, *mflag;
>> +    struct Flag *uflag, *dflag, *timestampflag;
>>     /* Initialize GIS Engine */
>>     G_gisinit(argv[0]);
>> @@ -74,14 +75,44 @@
>>     opt1 = G_define_standard_option(G_OPT_R_MAP);
>> +    rflag = G_define_flag();
>> +    rflag->key = 'r';
>> +    rflag->description = _("Print range only");
>> +    sflag = G_define_flag();
>> +    sflag->key = 's';
>> +    sflag->description =
>> +       _("Print raster map resolution (NS-res, EW-res) only");
>> +    tflag = G_define_flag();
>> +    tflag->key = 't';
>> +    tflag->description = _("Print raster map type only");
>>     gflag = G_define_flag();
>>     gflag->key = 'g';
>> -    gflag->description = _("Print basic info in shell script style");
>> +    gflag->description = _("Print map region only");
>>     hflag = G_define_flag();
>>     hflag->key = 'h';
>>     hflag->description = _("Print raster history instead of info");
>> +    uflag = G_define_flag();
>> +    uflag->key = 'u';
>> +    uflag->description = _("Print raster map data units only");
>> +    dflag = G_define_flag();
>> +    dflag->key = 'd';
>> +    dflag->description = _("Print raster map vertical datum only");
>> +    mflag = G_define_flag();
>> +    mflag->key = 'm';
>> +    mflag->description = _("Print map title only");
>> +    timestampflag = G_define_flag();
>> +    timestampflag->key = 'p';
>> +    timestampflag->description =
>> +       _("Print raster map timestamp (day.month.year hour:minute:seconds) only");
>>     if (G_parser(argc, argv))
>>        exit(EXIT_FAILURE);
>> @@ -115,8 +146,9 @@
>>     out = stdout;
>> -    /* no flags */
>> -    if (!gflag->answer && !hflag->answer) {
>> +    if (!rflag->answer && !sflag->answer && !tflag->answer &&
>> +       !gflag->answer && !hflag->answer && !timestampflag->answer &&
>> +       !mflag->answer && !uflag->answer && !dflag->answer) {
>>        divider('+');
>>        compose_line(out, "Layer:    %-29.29s  Date: %s", name,
>> @@ -289,10 +321,9 @@
>>        fprintf(out, "\n");
>> -    else {     /* g,h flag */
>> +    else {     /* r,s,t,g,h, or m flag */
>> -       if (gflag->answer) {
>> -           /* old rflag */
>> +       if (rflag->answer) {
>>            if (data_type == CELL_TYPE) {
>>                if (2 == Rast_read_range(name, "", &crange)) {
>>                    fprintf(out, "min=NULL\n");
>> @@ -311,7 +342,10 @@
>>                fprintf(out, "min=%.15g\n", zmin);
>>                fprintf(out, "max=%.15g\n", zmax);
>> +       if (gflag->answer) {
>>            G_format_northing(cellhd.north, tmp1, -1);
>>            G_format_northing(cellhd.south, tmp2, -1);
>>            fprintf(out, "north=%s\n", tmp1);
>> @@ -321,46 +355,47 @@
>>            G_format_easting(cellhd.west, tmp2, -1);
>>            fprintf(out, "east=%s\n", tmp1);
>>            fprintf(out, "west=%s\n", tmp2);
>> -           /* old sflag */
>> +       if (sflag->answer) {
>>            G_format_resolution(cellhd.ns_res, tmp3, cellhd.proj);
>>            fprintf(out, "nsres=%s\n", tmp3);
>>            G_format_resolution(cellhd.ew_res, tmp3, cellhd.proj);
>>            fprintf(out, "ewres=%s\n", tmp3);
>> -           /* new rows and columns parameters */
>> -           fprintf(out, "rows=%d\n", cellhd.rows);
>> -           fprintf(out, "cols=%d\n", cellhd.cols);
>> -           /* old tflag */
>> +       if (tflag->answer) {
>>            fprintf(out, "datatype=%s\n",
>>                    (data_type == CELL_TYPE ? "CELL" :
>>                     (data_type == DCELL_TYPE ? "DCELL" :
>>                      (data_type == FCELL_TYPE ? "FCELL" : "??"))));
>> -           /* old mflag */
>> +       if (mflag->answer) {
>>            fprintf(out, "title=%s (%s)\n", cats_ok ? cats.title :
>>                    "??", hist_ok ? Rast_get_history(&hist, HIST_TITLE) : "??");
>> -           /* old timestampflag */
>> +       if (timestampflag->answer) {
>>            if (time_ok && (first_time_ok || second_time_ok)) {
>>                G_format_timestamp(&ts, timebuff);
>>                /*Create the r.info timestamp string */
>>                fprintf(out, "timestamp=\"%s\"\n", timebuff);
>>            else {
>>                fprintf(out, "timestamp=\"none\"\n");
>> -           /* old uflag */
>> -           fprintf(out, "units=%s\n", units ? units : "(none)");
>> -           /* old dflag */
>> -           fprintf(out, "vertical_datum=%s\n", vdatum ? vdatum : "(none)");
>> +       if (uflag->answer)
>> +           fprintf(out, "units=%s\n", units ? units : "(none)");
>> +       if (dflag->answer)
>> +           fprintf(out, "vertical_datum=%s\n", vdatum ? vdatum : "(none)");
>>        if (hflag->answer) {
>>            if (hist_ok) {
>>                fprintf(out, "Data Source:\n");
>> @@ -375,7 +410,8 @@
>> +    }                          /* else rflag or sflag or tflag or gflag or hflag or mflag */
>>     return EXIT_SUCCESS;
>> grass-commit mailing list
>> grass-commit at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-commit
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
