[GRASS-dev] Re: [GRASS GIS] #1488: v.in.dxf wrapper not working
trac at osgeo.org
Mon Nov 14 15:02:29 EST 2011
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: v.in.dxf | Platform: Unspecified
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:14 cmbarton]:
> I fear that this could go on and on, and then pop up somewhere else. Is
there a cost that actually matters to either using 'ignore' in
DecodeString and EncodeString or using .replace(u'\ufffd',u'?') in both
cases?
Using 'ignore' will '''silently''' ignore conversion errors. The user may
then try to use the names shown in the GUI and have no clue as to why that
doesn't work. Using a replacement will alert the user to the fact that the
name shown is an approximation.
Using U+FFFD as the replacement (instead of e.g. a question mark) will
make it easier to locate all of the places which are using str() instead
of !EncodeString(). "Hiding" these errors will make it harder to fix them.
str(x) (where x is a Unicode string) is roughly equivalent to
x.encode(sys.getdefaultencoding(), 'strict'), which in turn is usually
equivalent to x.encode('ascii', 'strict').
In most of the places where str() is used, it's debatable whether either
the 'ascii' encoding or the 'strict' error behaviour are the correct
choice. In all probability, str() was used in order to duck the issue. But
if the GUI is to actually work in non-ASCII locales (meaning: the user is
working with files with non-ASCII names and/or non-ASCII contents; as
opposed to just having localised menus and labels), then the issues need
to be addressed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1488#comment:15>
