[GRASS-dev] How can I cange or modify the GUI for watershed analysis?
Sören Gebbert soerengebbert at googlemail.com
Tue Nov 15 07:08:55 EST 2011
2011/11/15 Sandip Maity <sandip.stesalit at gmail.com>:
> Dear Martin,
> I am using WXPYTHON.
> So, where I can use this comand "r.watershed--interface-description"
> Please help me.
Open a GRASS shell and type:
r.watershed --interface-description
To create a XML file, type:
r.watershed --interface-description > gui.xml
Don't forget the space between r.watershed and --interface-description.
In case you want a WPS XML process description to use with PyXB type:
r.watershed --wps-process-description > r_watershed_process.xml
Soeren
> sandip
> On Tue, Nov 15, 2011 at 4:26 PM, Martin Landa <landa.martin at gmail.com>
>> > Dear frnd,
>> > I am not getting "-interface-description".
>> > Please suggest me how can i get gui.xml?
>> ML
>> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
