[GRASS-dev] Re: [GRASS GIS] #620: Platform.make odd variables
settings
trac at osgeo.org
Mon Nov 21 15:52:06 EST 2011
#620: Platform.make odd variables settings
Reporter: frankie | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Installation | Version: 6.4.0 RCs
Keywords: g.extension | Platform: All
Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:24 manu]:
> Broken again on Ubuntu 11.10 and still "the Variable LOCATION_NAME not
set" problem
if you can, please try the debian build rules from DebianGIS git, and the
g.extension from devbr6, I just sync'd that to the latest behaviour of the
g.extension script yesterday. I would not be surprised if earlier versions
and combinations fail.
afair the "the Variable LOCATION_NAME not set" message does no harm and
can be ignored. can you attach the full output?
how are you building? manually or in a .deb package?
where are you running it from? directly from the build dir or after 'make
install', or from the .deb?
I tested 6.4.2rc2 on ubuntu 11.10 yesterday (debian sid too) while helping
Helmut, g.extension worked for me from the .deb, and from the build dir
for 6.5svn, but I will have another try in case I missed something.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/620#comment:25>
