[GRASS-dev] [GRASS GIS] #1497: OSGeo4W-GRASS: r.shaded.relief starts Windows XP mode (VM)
GRASS GIS trac at osgeo.org
Wed Nov 23 11:47:22 EST 2011
 Reporter:  pietror3  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  wxGUI     |     Version:  svn-trunk
 Keywords:            |    Platform:  MSWindows 7
      Cpu:  x86-64    |
 Using OSGeo4W-GRASS 7.svn on Windows7-64bit, when starting
 r.shaded.relief from the wxGUI menu, it starts indeed the
 Windows XP mode (virtual machine) and does not continue.
 Trying instead on command line, I get this error:
 GRASS 7.0.svn> r.shaded.relief.py
   File
 "C:\OSGeo4W\apps\grass\grass-7.0.svn/etc/gui/wxpython/gui_modules/menufor
 m.py", line 2223, in <module>
     task = gtask.grassTask(cmd[0], blackList = _blackList)
   File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/etc/python/grass/scr
 ipt/task.py", line 67, in __init__
   File "C:\OSGeo4W\apps\Python25\lib\xml\etree\ElementTree.py", line 964,
 in XML
     return parser.close()
   File "C:\OSGeo4W\apps\Python25\lib\xml\etree\ElementTree.py", line 1254,
 in cl
 ose
     self._parser.Parse("", 1) # end of data
 xml.parsers.expat.ExpatError: no element found: line 1, column 0
 GRASS 7.0.svn>
Ticket URL: <http://trac.osgeo.org/grass/ticket/1497>
