[GRASS-dev] r.mapcalc 32-bit ceiling
Rainer M Krug r.m.krug at gmail.com
Fri Nov 25 04:59:12 EST 2011
On Fri, Nov 25, 2011 at 4:31 AM, Andy Wickert <andrewwickert at gmail.com>wrote:
> Hi Grass-dev,
> I ran into an unexpected issue (to me, at least) with r.mapcalc:
> I was multiplying and dividing by some pretty big scalars, and one of
> those was greater than a 32-bit signed value (so >2**31). What mapcalc
> did was to reduce that value to 2**31 and carry on with operations.
> There was no warning, and I didn't find any information about this on
> the r.mapcalc help page, so I just wanted to alert (or possibly
> remind) the list that this exists and note that (as a non-developer)
> it took me a while to figure out that this was a problem. If there is
> an easy way to throw an error instead of silently hitting a ceiling,
> or this would be important enough to put on the manual webpage, I
> think it would be helpful, and certainly would have saved me a ton of
> time.
I ran into the same issue when I was using integers - I solved it by
converting the raster to double. But I agree with Andy: I think GRASS
should throw an error when the rollover occurs, or use a dedicated value in
this cell, so that one can check afterwards. Thinking about it: an error is
asked for, as something went wrong.
Cheers,
Rainer
> Thanks, and happy Thanksgiving to those in the USA!
> Andy
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax (F):       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20111125/cf89d659/attachment.html
