[GRASS-dev] Re: [GRASS-SVN] r49205 - in grass/trunk: lib/python
raster/r.info
Martin Landa
landa.martin at gmail.com
Sat Nov 26 18:07:54 EST 2011
2011/11/18 Hamish <hamish_b at yahoo.com>:
> Hamish wrote:
>> simple, clean, consistent, and doesn't stop others
>> from working the way they want to work.
> well, maybe "consistent" for all sets/perspectives is
> the part we're working on right now. :-)
current situation is
r.info
-g Print raster array information only
-e Print extended metadata information only
v.info
-g Print region info in shell script style
-e Print extended metadata info in shell script style
which forces to open discussion again. I would still incline to use
`-g` for shell script output as used in others modules. I have counted
more than 45 modules in trunk which use `-g` for shell script style
output. I don't see any reason why `r.info` or `v.info` should be
exceptions.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
