[GRASS-dev] [GRASS GIS] #1499: v.surf.rst in trunk doesn't create write the output map
GRASS GIS trac at osgeo.org
Tue Nov 29 00:57:57 EST 2011
 Reporter:  hamish      |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  7.0.0
Component:  Vector      |     Version:  svn-trunk
 Keywords:  v.surf.rst  |    Platform:  Linux
      Cpu:  x86-64      |
 I can't get v.surf.rst in trunk to create any output.
 spearfish:
 g.region -d
 g.copy vect=archsites,arch_cp
 v.build arch_cp
 v.surf.rst in=arch_cp zcol=cat elev=test.rst
 Processing segments...
  100%
 WARNING: Raster map <test.rst> not found
 ERROR: Unable to write raster maps - try to increase resolution
 no matter what I try, same thing.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1499>
