[GRASS-dev] Re: [GRASS-SVN] r49437 - grass/trunk/gui/wxpython
Martin Landa
landa.martin at gmail.com
Wed Nov 30 17:32:43 EST 2011
2011/11/30 Martin Landa <landa.martin at gmail.com>:
> no, it's not purpose of `--with(out)-widgets` switch. It was
> introduced to control compilation of modules which are linked against
> wxWidgets library, eg. `wximgview`. In other words, with
> `--without-wxwidgets` you should get GRASS without modules which are
> using wxWidgets library directly. It's not the case of wxGUI. Probably
> we should think about introducing a new configure switch for disabling
> wxGUI.
similarly `--without-python` doesn't mean that python scripts will be
no installed. It just means that the programs which are built against
python libraries will be not compiled.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
