[GRASS-dev] [GRASS GIS] #1459: X Window System error
trac at osgeo.org
Wed Oct 5 10:27:01 EDT 2011
Reporter: andressilvam | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone:
Component: wxGUI | Version: unspecified
Keywords: | Platform: Linux
Cpu: x86-64 |
I am working normally in GRASS and suddenly shutdown the wxGUI but not the
terminal. I am working with Xubuntu 64 bits. I get the following mensagge
in the terminal:
The program 'python' received an X Window System error.
This probably reflects a bug in the program.
The error was 'RenderBadPicture (invalid Picture parameter)'.
(Details: serial 591174 error_code 162 request_code 149 minor_code 26)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error()
function.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1459>
