[GRASS-dev] r.reclass only for int maps
Mon Oct 10 03:55:20 EDT 2011
Martin Landa wrote:
> >> Yes; a reclass table maps integers to integers.
> then probably r.reclass should at least print a warning when `input`
> is CELL raster map(?).
Presumably you mean "... is *not* a CELL ..."?
Currently, it actually checks the map type so that it can use the
correct format for printing the range. It should generate a fatal
error if the input= map type isn't CELL.
