[GRASS-dev] Re: [GRASS GIS] #1457: Zoom in Georectify Does not Work
GRASS GIS trac at osgeo.org
Wed Oct 12 08:07:45 EDT 2011
 Reporter:  jjrambo           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  wxGUI             |     Version:  svn-trunk
 Keywords:  Zoom, Georectify  |    Platform:  Linux
      Cpu:  x86-32            |
Comment(by annakrat):
 Replying to [comment:4 martinl]:
 > Replying to [comment:2 mmetz]:
 > > I guess the check for alignExtent must be disabled for the
 Georectifier. Martin, is this alignExtent thing something new or at least
 newer than the Georectifier?
 > yes, see r47987. I think there is no need to disable this feature in
 georectifier(?) For quick `gcpmapdisp.py` code should be updated or
 rewrite code as I suggested and use common super-class for also for
 `mapdisp.MapFrame`. This avoid such bugs in the future and also made life
 easier for implementing similar tools, like wxGUI i.class, etc.
 As you might have noticed we are working on this super-class. We found
 quite a lot of  code related to georectifier - GRMapWindow (especially in
 mapdisp.py, mapdisp_window.py), which seems to be useless. For example
 there are `toolbars['georect']` and `toolbars['gcpdisp']` (which is used
 now). Is this obsolete? If yes, we will clean the code.
 Anna and Vaclav
Ticket URL: <http://trac.osgeo.org/grass/ticket/1457#comment:12>
