[GRASS-dev] Re: [GRASS GIS] #1457: Zoom in Georectify Does not Work
GRASS GIS trac at osgeo.org
Wed Oct 12 09:56:41 EDT 2011
 Reporter:  jjrambo           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  wxGUI             |     Version:  svn-trunk
 Keywords:  Zoom, Georectify  |    Platform:  Linux
      Cpu:  x86-32            |
Comment(by annakrat):
 Replying to [comment:13 mmetz]:
 > Replying to [comment:12 annakrat]:
 > > As you might have noticed we are working on this super-class. We found
 quite a lot of  code related to georectifier - GRMapWindow (especially in
 mapdisp.py, mapdisp_window.py), which seems to be useless. For example
 there are `toolbars['georect']` and `toolbars['gcpdisp']` (which is used
 now). Is this obsolete? If yes, we will clean the code.
 > `toolbars['georect']` is unused, it is a left-over from the previous
 version of the georectifier. Only `toolbars['gcpdisp']` is used by the
 current georectifier.
 > I will help adjusting the code as soon as I have a bit more breathing
 time.
 > Markus M
 OK, we will remove the unused code.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1457#comment:14>
