[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem with path to $GISBASE
GRASS GIS trac at osgeo.org
Wed Oct 12 13:20:35 EDT 2011
 Reporter:  hellik                                             |       Owner:  grass-dev@…
     Type:  defect                                             |      Status:  new
 Priority:  major                                              |   Milestone:  6.4.2
Component:  Installation                                       |     Version:  svn-releasebranch64
 Keywords:  wingrass, g.extension, path, installation, addons  |    Platform:  MSWindows Vista
      Cpu:  x86-32                                             |
Comment(by hellik):
 Replying to [comment:40 neteler]:
 > AFAIK some improvements have been done in SVN, please retry.
 there is no improvement at the moment for compiling with spaces in path,
 but you're informed why the compilation fails:
 g.extension --verbose extension=r.stream.angle
 svnurl=https://svn.osgeo.org/grass/grass-addons
 Using WGET for downloading data.
 GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
 The GRASS program path: [c:/Program Files/GRASS 6.4RC1] contains a space.
 The build which follows will likely fail.
 Fetching <r.stream.angle> from GRASS-Addons SVN (be patient)...
 A    r.stream.angle\tangent.c
 A    r.stream.angle\init.c
 A    r.stream.angle\main.c
 A    r.stream.angle\description.html
 A    r.stream.angle\global.h
 A    r.stream.angle\seg_line.c
 A    r.stream.angle\io.c
 A    r.stream.angle\order.c
 A    r.stream.angle\Makefile
 Checked out revision 48766.
 Compiling <r.stream.angle>...
 Makefile:12: c:/Program: No such file or directory
 Makefile:12: Files/GRASS: No such file or directory
 Makefile:12: 6.4RC1/include/Make/Module.make: No such file
 or directory
 make: *** No rule to make target
 `6.4RC1/include/Make/Module.make'.  Stop.
 ERROR: Compilation failed, sorry. Please check above error messages.
 rm: cannot remove directory `C:\\gisdata\\grassdata/nc_spm_0
 8/user1/.tmp/6060.0/r.stream.angle': Permission denied
 (Wed Oct 12 19:14:25 2011) Command finished (24 sec)
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1178#comment:41>
