[GRASS-dev] r.pack failing on reclassed maps
Glynn Clements
glynn at gclements.plus.com
Thu Oct 13 05:12:47 EDT 2011
Markus Neteler wrote:
> r.pack is failing on reclassed maps and just packaging the reclass stuff.
> how to deal with that?
> - either fatal error with a reasonable suggestion to the user
> - or generate internally a map copy with r.mapcalc (slower), then package
First, is this actually a failure?
In any case, there doesn't appear to be a supported programmatic
method for determining that a map is a reclass. r.info includes
relcass information in the default "formatted" output, and in the
output for -h, but neither of these are designed to be
machine-readable.
